In the process of doing tag all for How to filter wall tags by its name if we just wanted to show wall tags only for certain wall types. Or filter by word “contains” in filter. I tried creating but was unsuccessful? It may be applicable to any annotation families if we can do that ?
Instead of rule-based filter, what about selection set filter? Select on a tag, right-click, Select All Instances=>In Entire Project, and add them all to a Selection Set.
Hi @Anonymous
If you are trying to just tag specific wall types, I would start by isolating those wall types,
i.e. create a filter that selects all wall types you don't want to tag, add this to a View, switch off the all wall type you don't want to tag, then "tag all", then switch the walls back on or just remove the filter.
