looking for best way to hide un-needed views from current submittal set
4 ANTWORTEN 4
Nachricht 1 von 5
skyeg321
475 Aufrufe, 4 Antworten
I am working on a large project with lots of interior elevations and sections that are not needed for the building submittal package. We do want to keep the views in the project so we can provide the owners/ builders with that information later. What is the best way to hide these elevation and section markers in plan view for now? Without manually hiding all of them? A filter of some sort?
4 ANTWORTEN 4
Nachricht 2 von 5
Ahmed_Muharram
als Antwort auf: skyeg321
use project browser organization and make a shared project parameter for views that is not used in sheets and filter using it
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Nachricht 3 von 5
hmunsell
For the Section markers you can create a Filter and apply the filter to the views. The filter can look at the View Name or other parameters to filter them out.
The Elevations are a little trickier. you can make a filter to filter the elevation bubble the same way as a Section, but the Elevation Markers are a little trickier to get rid of.
Howard Munsell
Nachricht 4 von 5
I would suggest opening a section or elevation and duplicating the type (under Edit Type), and naming the new section/elevation to 'Interior" (or something similar).  Change all of the interior sections/elevations to the new type.  The views will be rearranged in the browser under new categories.  Then use view filters to filter out the sections or elevations with 'Interior' in the name.
Nachricht 5 von 5
Are you asking if you can prevent these Project Views from being accessed in the deliverable?
