Looking for a family of windows that can create a steeply sloped outside sill
Message 1 of 13
The company I work for does some custom homes with small clerestory or other windows set high in a thick wall. With a 45 degree stucco sill on the outside. Kinda makes the home look massive like an adobe or straw bale wall. Anyone know where I can find such an item.
Here's a sketch of the condition: http://prntscr.com/jzqlsc
I am just learning the program and this detail is key. Have tried a couple ways of modeling it without success, thanks.
Replies (12)
Message 2 of 13
A window "opening" will cut through any depth host.
To create a slope sill, you'll need to use a Void Cut, in lieu of an Opening, but it too can be constrained to the exterior and interior faces of the host wall.
Message 3 of 13
Use a void to create the opening.  See screencast for a demonstration in a few minutes.
https://knowledge.autodesk.com/community/screencast/b53cc55b-9fd6-49cc-a657-6019c6416d8d
Screencast will be displayed here after you click Post.
Message 4 of 13
Corsten.Au
Hello
Check out  the window family uploaded in the dropbox..
you will get results shown... Edit it the way you want further..
https://www.dropbox.com/sh/xh2p48vrjt6akx3/AABtMPxRkc2Ando0RALGg66na?dl=0
Cheers !
Corsten
Building Designer
Message 5 of 13
Thanks so much! Very helpful.
Whenever I see the image of a four-armed elephant I will think of you Ganesh!
Metric is not a problem either, the window works out to be very close to 24" by 24" "Old English" size.
Message 6 of 13
@Anonymous: Here's another family for your perusal, that I did for another forum member a while back.  It may give you some additional insight on how to construct wall opening families of your own.  This one is an concave arched passageway opening, and is fully parametric so that instances of it placed in the project can be custom-sized (i.e. Height, Width, Slope Angle, Arch Spring Offset, etc.).
Message 7 of 13
Sorry, @Anonymous, I just realized the family I posted above is not the one I was referring to.  I think that one might have been the one the other member posted and needed help with.  Look this one over and let me know what you think.
Message 8 of 13
latest 3d view fwiw
http://prntscr.com/k0zbao
Message 9 of 13
m.heydari
Can U please send that family again?
its not anymore  in dropbox.
Message 10 of 13
Corsten.Au
Hello
heres the link for Revit file.
https://corstenau-my.sharepoint.com/:f:/g/personal/ganesh_corsten_com_au/EisApF34x1dDiuX4egFsFKABKYX...
Opening cut, extend with parameterOpening cut, extend with parameterfill wall part which is getting cut due to openingfill wall part which is getting cut due to openingfinal result.final result.
Corsten
Building Designer
Message 11 of 13
m.heydari
Thanks a lot
Message 12 of 13
zoe2.restrick
Community Visitor
Community Visitor
could you please post family again
Message 13 of 13
rvanbeersYGF3Y
Community Visitor
Community Visitor
could you please reshare the download link
