Looking for a end panel trim of base cabinets
octavio2
octavio2
Looking for an end panel trim of a base cabinet.  It is the one at the end of a base cabinet assembly where there is a dishwasher at the end and you want to end the side of the dishwasher with the end trim to match the base cabinets material (and of course, so you do not see the side of the dishwasher).
Tried to do one family, but it did not work.   Revit out of the box comes with the base filler and the corner base filler, but it does not come with the end panel.  Tried to find it in Revit City, but did not find it (unless it has another name that I am not aware of).
Where can I find one that can be shared and used?
Thanks in advance.
What about modeling the end panel as a Wall Type in the Project?  Or, modifying (or using as-is) one of the Base Cabinets in the stock Revit Content Library?
...maybe you could make this Base Cabinet-Built In.rfa from the stock Revit Content Library work.
What about shelves?  😉
octavio2
Thanks Bart.
octavio2
RE: Side panel for base cabinets -  I found one that I had to revise slightly, using Revit 2021, and it works OK now, it seems.
Thanks for your shelf end, Barth, it looks terrific, and you did a very nice presentation there.  Only thing, I just use Revit 2021, but thanks again for your responses.
