loft function does not work well
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
denis_kraenert
458 Aufrufe, 4 Antworten
In ACAD I can loft following 2 section easy. Revit produce different result with same function. How to get the same result in Revit. Picture: left import from ACAD, right result loft function in Revit.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: denis_kraenert
Are you in a massing environment? You might get a better result using a sweep blend in a "regular" environment.
In-Place Component Sweep Blend:
Nachricht 3 von 5
loboarch
Could you give us an image of the 2 (or multiple profiles) you are using in Revit to loft the form?  Or even better a file that has the form, and a copy of the profiles you are using. With that it might be easier to troubleshoot exactly what might be happening. ACAD and Revit should produce the same form using the same profiles.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 4 von 5
denis_kraenert
als Antwort auf: loboarch
I solved the issue by using 2 halfes. Then blend function works fine.
Nachricht 5 von 5
loboarch
Glad you resolved it. Thanks for the image illustrating.
Jeff Hanson
Revit Help |
