Loft floor plan
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
anthony_brown2EK7PV
247 Aufrufe, 1 Antwort
Loft floor plan
I have attached a picture for reference.
I need to have a loft plan included in my sheets, but cannot seem to get my lofts to appear even though I am setting the underlay as well as the view range accordingly. I do not know what to do, as well as, I feel drawing up a loft for the sake of it would be wrong. As you can see in my pictures, I have a loft (yes its a floor) but it is not showing up onto the loft plan.
Please help.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: anthony_brown2EK7PV
Is the loft on a separate Level or the same level as the main floor but with different elevation?
If you need to have a floor plan of the loft then you need to change the view range to cut above the loft, view range bottom @ the floor of the loft, view depth at the level below (if you want to see what below for reference).  There is no need for underlay.
Help | About the View Range | Autodesk
