Locking Revit Views
9 ANTWORTEN 9
Nachricht 1 von 10
mark
478 Aufrufe, 9 Antworten
Locking Revit Views
Okay, is there any way I can "lock" views so that any new items added to the model don't show in that view?
For instance let's say that I've set out all the tables in all the classrooms in a school and created lots of layout drawings etc, job done.
I'm then asked by the contractor to supply some chairs in the rooms so I add them in.
I don't want the chairs to show up in all the plan views, sections and elevations I've previously created and more importantly I don't want to have to trawl through all my previous work hiding them.
Tables and chairs are just an example, this situation can apply to all sorts of items..
Any ideas?
Please?
Is there any way of
9 ANTWORTEN 9
Nachricht 2 von 10
Ilic.Andrej
als Antwort auf: mark
You can create a rule based filter. A rule may be a type mark. Assign that filter to the view templates.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 10
chrisplyler
You can place the chairs into a Design Option, and only make one new view that displays this Design Option.
Nachricht 4 von 10
cbcarch
In this case, Worksets may also be an option--(although best practice usually points to Filters for visibility methods.)
So--there is no "one correct way" to do it. These methods can all work.
-Design Options
-Worksets
-Filters
Apply to View templates to globally control visibility of the "new chairs" in all the views/sheets.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 5 von 10
Viveka_CD
Hi @mark
Since you don't want the chairs to show up in all the plan views you could create a view filter that identifies elements based on categories and parameter values.
Videos: Create a Rule-Based View Filter
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Nachricht 6 von 10
cbcarch
als Antwort auf: Viveka_CD
Like drgrozozo mentioned above?
Cliff B. Collins
Nachricht 7 von 10
Viveka_CD
als Antwort auf: cbcarch
As suggested by @cbcarch Design Options and Worksets also work.  Creating a rule-based filter selection you can achieve similar results as @Ilic.Andrej mentions. Also, see Manage Selection-Based Filters
Here are some additional resources on the same:
Hope that helps!
Nachricht 8 von 10
bimscape
I am also inclined to add "Phases" into the list of possible suggestions.
If you are trying to document / model a linear sequence of events- ie at this stage there are 20 chairs in the room, next week (due to Contractor instruction) there are 43 Chairs in the room- seems like Phases may be appropriate?
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Nachricht 9 von 10
mark
als Antwort auf: bimscape
Thanks all for your suggestions, I'll have a look through the links and have a go.
Smiley (fröhlich)
Mark
Nachricht 10 von 10
Viveka_CD
Sounds good @mark
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. this will help them find answers more quickly.
