locker family not associating with host room
jledgewood409
jledgewood409
i have a locker family and i would like to create a schedule that shows the lockers that are in each locker room (mens & womens.) i have created a furniture schedule and included these fields; room name, room number, family and type, mark, count, type mark. when the schedule is created the columns for room name & room number are blank. it seems as though my lockers are not associating with the room that they are located in. i have moved the room calculation point so that it is not on the ground plane and not in the center of the locker family and still no luck. i was hoping someone has a solution?
i am attaching the locker family for your review.
bimscape
All scheduling correctly here- using your locker family and 3 test Rooms.
Are you using Phases or Design Options?  Are you using Filters in your Schedule?
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
jledgewood409
no phases or design options for this project.
I do have a filter applied.
filter by: Type Mark contains L12X18
bimscape
What height do you have the Limit Offset at, for your Rooms?
Kind regards,
Ian
jledgewood409
I have played with the limit heights with no avail. I tried something new. I copied the rooms and lockers in a new revit file and created a schedule. for some reason it populated in that schedule. so I did an "insert from file" and brought the working schedule into my project and the room names and numbers populate. go figure??
Corsten.Au
furniture room.JPGIf you are not getting Room fied for the locker family, then just recreate locker family using " EXISTING FURNITURE "...
simple changing family parameter to Furniture may not work..
Corsten
Building Designer
jledgewood409
so I found out that if I move the room calculation point and the fact that one of my rooms from the level below was bleeding into the room above I was able to make the adjustments and now the rooms populate on my schedule.
