locked "greyed out" properties on a family
27 ANTWORTEN 27
GELÖST
Nachricht 1 von 28
uaa061
8561 Aufrufe, 27 Antworten
Hey Guys, so i have a pendant light revit family that i am trying to edit and just extend the length on it but I haven't been able to unlock the properties. They seem to be locked, I cant find a formula that's locking them though. Any help? Thanks in advance.
27 ANTWORTEN 27
Nachricht 2 von 28
mhiserZFHXS
als Antwort auf: uaa061
Have you opened the family? Values are grayed out when they are controlled by an equation.
Nachricht 3 von 28
Edit the family and remove the value in the formula box of the parameter(s).
Nachricht 4 von 28
You're not, by chance, fighting with a legacy version of the OOTB "Pendant Light - Hemisphere.rfa"?  If so, it was built poorly and needed to be fixed to flex correctly (i.e. remove second "Origin" Ref. Plane, remove dimension in geometry sketch mode, etc.)
Whatever family it is, post it here and we'll tell you exactly how to fix it.
Nachricht 5 von 28
uaa061
als Antwort auf: barthbradley
Still trying to figure it out, but thanks for the help. Ill post the family here.
Nachricht 6 von 28
mhiserZFHXS
Delete the formulas... As we said.
Nachricht 7 von 28
You can't size this family parametrically.  It is what it is.
Nachricht 8 von 28
uaa061
als Antwort auf: mhiserZFHXS
Got it, thanks
Nachricht 9 von 28
@uaa061 wrote:
Got it, thanks
I don't think you do "got it".
You told us that you wanted to "edit and just extend the length".   You can't extend the length with any one of those parameters - formula-driven or not.  The family doesn't flex parametrically.  It is what it is - period.  The only thing you accomplish by removing those formulas is dumb the family down even further.
 "Edit the family and remove the value in the formula box of the parameter(s)" is not a solution. Why you marked it as one, is bewildering to me.
Nachricht 10 von 28
mhiserZFHXS
@barthbradley
It's a partial solution. He didn't understand why parameters were grayed out. But yes, now there is another issue on top of that.
Nachricht 11 von 28
It's NOT a solution, unless the OP wants to dumb the Family down.  Those formulas carry INFORMATION over to the BIM Model.
Nachricht 12 von 28
mhiserZFHXS
Considering they are editing the family, I doubt they are actually using this specific product in a project. So most, if not all, of that information is irrelevant/wrong.
Tons of bad families downloaded for free have stuff like this. Understanding how to get rid of it is important.
Nachricht 13 von 28
uaa061
lol no I did get it. This is for a rendering model so I don't need the formula information, it's not going into BIM. I was able to take out the formula for the length in the family and load it in and adjust as needed. So the solution that was stated was correct and helped me.
Nachricht 14 von 28
uaa061
yes EXACTLY, thank you for explaining that :leicht_lächelndes_Gesicht:
Nachricht 15 von 28
You posted a question about a REVIT FAMILY on a REVIT FORUM, saying that you were "trying to edit and just extend the length".  Now you are saying this is all about Rendering and not about BIM???  That doesn't make one iota of sense.  In fact, it sounds ludicrous.
If you are ever in the neighborhood again and want a way to "extend the length" parametrically, look me up.  I've got a solution.
 @barthbradley - this post has been edited due to Community Rules & Etiquette violation.
Nachricht 16 von 28
How do you know that "most, if not all, of that information is irrelevant/wrong".  Do you work for Kohler?  Also, what specifically is "bad" about this particular family?  I don't see any fault with it.  Here is the product information:
 K-23663-PE01 (kohler.com)
Nachricht 17 von 28
mhiserZFHXS
If they are just using it for rendering, and not actually putting this product in the specs, then all of that stuff about voltage and what bulbs to use and all of that is irrelevant.
People don't always use the exact item they find on BIMobject or other free sites in their built project. I'd go as far as to say most don't. Its a placeholder. So manufacturers including all of that information is usually completely unnecessary. This isn't the worst example, as some BIMobject families contains dozens upon dozens of ridiculous parameters. But still, for this case, those handful of locked parameters are unnecessary.
Nachricht 18 von 28
uaa061
oof who knew people could get so emotional on a Revit forum. yes, our firm uses the revit model to render with enscape so like THE GUY SAID I don't need any of the formula information because it is irrelevant in this model.
Nachricht 19 von 28
Okay, I'll bite. How do those Family Parameters relate to Rendering - which, by the way, you never mentioned up front?  Serious question.   If you can answer that, then I'll be happy to eat crow.
Nachricht 20 von 28
uaa061
Uhh didn't know I had to tell you it was a rendering model so I could extend the length of a lighting fixture lol. I guess I can break it down for you, I wanted to extend the light, so I asked how do I do that because it was locked, solution: remove the formula, now I can extend the length of it so it looks correct in revit and now I can use enscape to render it. I don't get what your not getting, or why you're going crazy over it haha.
