locked properties
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
2710 Aufrufe, 7 Antworten
locked properties
When I select an element and choose "Edit type" to see the properties, they are all greyed out so I cannot make a duplicate or edit them.
Is there a way to make them available to edit?
7 ANTWORTEN 7
Nachricht 2 von 8
pendean
als Antwort auf: Anonymous
Which "element" did you select exactly, and is it on a locked layer (or is layer 0 locked)?
Nachricht 3 von 8
als Antwort auf: pendean
Same for anything in the model. Here i selected a parapet detail which you can see the properties greyed out. Same if i take it through to "Edit"
Nachricht 4 von 8
dbroad
I think you want to ask this in the Revit forum but I don't think you can modify a linked file without opening it.
Architect, Registered NC, VA, SC, & GA.
Nachricht 5 von 8
hmunsell
there are several reasons properties will be grayed out.
  • if there is a View template controlling it
  • if its in a Design option
  • If it is in a Linked model
  • and several others.....
as @dbroad  mentioned, it looks like this may be in a link. if it is in a link you can only get information from it, not edit it. if you need to edit it, you need to open the linked file.
Howard Munsell
Nachricht 6 von 8
mostafa2414
This element is part of a linked revit file.
You should open the linked file separately and edit it.
Nachricht 7 von 8
Because it's an IFC.
Nachricht 8 von 8
hmunsell
als Antwort auf: barthbradley
Ahhhhh, Good catch... i hadn't noticed the IFC parameters filled in.
Howard Munsell
