Hi Community,
Today I came across this issue, one of my modelers approached me and said that she cannot see certain elements in the linked CAD file. Then I did a check and identified that those elements are in the locked layers are not visible in Revit 2019. Even I did the latest update as well (Revit 2019.2.2 | 19.2.20.24). Still, the problem exists.
Then I turn back to my machine to further investigate the problem, surprisingly my machine got no problem and I can able to see the elements in the locked layer.
Do anyone has a solution to fix this issue, please let me know.
So, the issue as I understand it, is that there is no problem except on one machine. Is that correct? Did you happen to check it on another computer. That would be the definitive troubleshooting step in my mind in order to reach a conclusion. No?
We can test here if you would like to post it.
have you try to untick use hardware acceleration and change the link cad from background to foreground and see if helps. thanks
