Lock wall fill pattern scale in multiple views?
1 ANTWORT 1
Nachricht 1 von 2
1242 Aufrufe, 1 Antwort
Hello guys,
Is there any way to lock the scale of wall section fill patterns in multiple views with different scales?
For example, I use a fill pattern of dense vertical lines as the wall cut pattern in the expanded partial floor plan (scale=1/4"), but the overall floor plan (scale=1/16") shows it very sparse. I want it to be the same density. I know it's not possible in the old versions. Is it possible in Revit 2022?
Thank you.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Still only Drafting Patterns available for Cut Patterns in 2022.
