Hi everyone,
I have been working on a product for a while. My aim is to make the product redesign-configurable in Revit. -image 0- in this product user can move every rail through the x and y-axis and after that, we going to export what have they using for this product.
-image 1- this product basically the same but more detailed. I've locked each rail and connector with each other except r5 and r4. when I am trying to lock them each other and move one of them it goes wrongly -image 2-. I tried to make them group; it works with each other but in this scenario, I can not control their dimension on x-axis.
The second question is I want to set up a length limit for rails. (400-425-800-825...) The user should use one length which I decided. when we move a rail to one axis the dimension would be one of those dimensions.
After all these things we are going to export rails and connector types and amount.
Hope I express myself well, if you have any question please don't hesitate. if anyone want to see the file I can share.
Thanks for all your help.
Sorry, but there's a lot of work to be done here if your aim it to build this into a synergetic, parametric assembly. I thought you were having a small issue I could easily resolve for you. I see now, you are just starting. Generally, we save of the modeling and assembly of the geometries to a last, and first concentrate on building a parametric framework using Ref. Lines and Ref. Planes. Then afterwards, host and constrain the model geometries to the work planes of the parametric framework. In this case, I would suggest modeling a lot of the assembly's components in their own families - making sure they properly flex parametrically in their own Families - and then nest them into the Host/Parent Family, place them where they need to be on the framework and then associate their Family Parameters to Host/Parent Family Parameters.
hi @Anonymous actually I made what you said before but the problem on that way is rails are family and I can not control their size via reference plane. What I want to achieve is when I move a reference plane the rail family should turn 400 to 800. Please find my file attachment.
Many thanks for your time.
