Location Position Changed Error
We've encountered a couple of projects that show us this error (attached) every time we sync our files.  This latest one just started doing it randomly after we added a design option.  It prompts us for every instance of a link and every time we save to central.  How do I make it stop? Cat Sad
Lance.Coffey
Autodesk Support
Autodesk Support
I found the following document regarding this message:
Location Position Changed dialog when saving in Revit
http://usa.autodesk.com/getdoc/id=TS14334953
I also found the following forum thread regarding the message (with Revit 2010):
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Revit-2010-Shared-Coordinates/td-p/2558246
Lance Coffey
Technical Support Specialist
