Location line
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1352 Aufrufe, 3 Antworten
Location line
Hello, someone can say me the meaning of "location line"?
If I change from exterior to core centerline change the potision to click for extend or retire the wall, but there is athor reason from this?
Thank's
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
When you draw a wall by picking 2 points, the line between these 2 points is the wall location line. If you click on the flip arrow, the location line acts as the base line for flipping. If f you change the wall to a thicker or thinner type, the location line remains in place and the thickness changes around it.
Nachricht 3 von 4
BiBO_Craig
als Antwort auf: ToanDN
Is there any reason why Revit LT 2018 will not let me change the location line, top or bottom constraints?  I can only choose centre line and unconnected height!?  So frustrating!!
Think this could be graphics issue because if I start to type the location line or height constraint I can get different choices.  Really slow and frustrating doing it this way though
Nachricht 4 von 4
als Antwort auf: BiBO_Craig
hi craig,
did you ever figure out what was causing this issue? I am experiencing a similar problem.
thanks,
thomas
