Hello, someone can say me the meaning of "location line"?
If I change from exterior to core centerline change the potision to click for extend or retire the wall, but there is athor reason from this?
Thank's
Solved by ToanDN. Go to Solution.
Is there any reason why Revit LT 2018 will not let me change the location line, top or bottom constraints? I can only choose centre line and unconnected height!? So frustrating!!
Think this could be graphics issue because if I start to type the location line or height constraint I can get different choices. Really slow and frustrating doing it this way though
hi craig,
did you ever figure out what was causing this issue? I am experiencing a similar problem.
thanks,
thomas
