Locating a Geometry Parameter
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
307 Aufrufe, 3 Antworten
Does anyone know a way to search for a geometry parameter, that has already showing up in the type box, and is driving geometry, but can't be seen in any of the views?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
It's probably hidden inside a piece of geometry, like a sweep  or extrusion. It's happened to me before. Drives my crazy! I tell people not to define ref lines and dimension INSIDE sketch mode!
Nachricht 3 von 4
als Antwort auf: barthbradley
Hello! I feel you, I mean I've been a modeler 6 years and recently became quickly proficient at families. One of the FIRST things every class I took or book I read says "Don't constrain the geometry inside the sketch", HAHA!
So, you are saying open all the geometry in sketch mode and hunt for it? I think that's the only way. I'd like if Autodesk adds a "find parameter" button :leicht_lächelndes_Gesicht:
Nachricht 4 von 4
Alfredo_Medina
@Anonymous
Maybe you are using nested families? In that case, you don't see any dimensions or constraints in the view, but the parameter is still driving the geometry.
