loading cars
loading cars
Message 1 of 9
loading cars
hi
am using revit 2014 and when i get into 'element de details' to load cars, it refuses that they are not components. through which element should i pass to load them
Replies (8)
Message 2 of 9
From which folder did you load the 'Cars'? Are you thinking to place them as 3D cars, or as symbols on plans and elevations?
Message 3 of 9
my revit is installed in french. i want to put them as 3d cars and i loaded them from a folder called 'element de details'
Message 4 of 9
patrick.emin
Hi, we have a french forum here : https://forums.autodesk.com/t5/revit-et-bim-francais/bd-p/198
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 5 of 9
"Element de details" sounds like 2D Detail components. I don't remember seeing any 3D cars in Revit stock families. You may need to download them from other sources, for example: http://www.bibliocad.com/library/car_86994
Message 6 of 9
constantin.stroescu
I used in my projects, car images in order to create more suggestive views for presentation.
I used several all ready done families gathered from the network or/and even .png images applied directly in a sheet .
Most of the car families I found , are in Site Category.
they can be :
either
  • Component (Build>Component>Place a Component - Load )> category Site . In this category I found 3d modeled families  or a collection of nested Detail Items (usually they have no 3d representation , but they appear in all ortho views and they a quite high detailed). The car can be seen in any View , (excepting the case of the nested Detail Items ). A combination of 3d modeled with nested Detail Items for Top,Sides,Front and Rear would be ideal , but I did not found such examples.
or
  • Detail Items ( Annotate>Detail Component) that could be placed on any ortho view (Plans, Elevations, Sections) . Using this method , you can see the car only in that View in which it is placed
Constantin Stroescu
Message 7 of 9
constantin.stroescu
a large amount of cars can be found on:
http://www.revitcity.com/
Downloads >Transportation.
a big library with free objects of good quality.
Constantin Stroescu
Message 8 of 9
FGPerraudin
Bonjour Morrelle,
Il te faut juste savoir si ton élément voitue est en 2D ou 3D.
Pour ce faire, ouvre la famille que tu veux charger et regarde son type (dans l'onglet créer > propriétés>le petit bouton avec le dossier, dans la liste la catégorie de famille sera surlignée)
Si c'est bien un élément de détail, il faut passer par l'onglet Annoter > Element de détail (ou composant, je ne me rappelle plus en français) pour l'utiliser dans une VUE (élément 2D, donc qui n'existe que dans la vue en cours)
Si c'est une famille 3D, essaie de passer par l'onglet insérer > charger une famille, ce qui te permettra de charger n'importe quel type de famille 3D, de ne pas être limité par la catégorie. Une famille 3D peut tout de même intégrer des éléments de détails qui ne s'affichent que dans les vues coupant ton modèle perpendiculairement...
Voilà, ça devrait résoudre ton soucis!
François
Francois-Gabriel Perraudin
BIM management and coaching
Message 9 of 9
please, what are the other sites to downloading vehicles for Revit
