Loading a profile for a Wall sweep
I am trying to load a profile. I choose it and it seems to be okay, but I don't see in the list.
Any idea? It's from the family, called "M_Footing-Rectangular"
Isabel
Accepted solutions (3)
RDAOU
Hi @Anonymous
there are several types of profiles and each has a purpose. I.e.: if it is for a sweep it needs to be set for sweeps.
  1. Open the profile family in family editor, then save it as a new family
  2. on the properties palette the is a drop down where you define the usage of this profile, pull down the menu and select sweep then click apply
  3. save and load the new family into ur project
the new profile should be listed
edit ... the profile u mentioned is not a profile it is an actual family for a footing . Profiles are 2 D elements
RDAOU
See screencast bellow - clarifies the above
Thanks a lot for the screencast explanation. The thing is, the guy I'm currently watching in a tutorial, is creating a foundation attached to the "wall" he is selecting above the excavation.
This is the link: https://www.youtube.com/watch?v=uoILXkuUOd8
if you have time for watching it.
I'm not sure if it is correct to the select the file I commented before from the Structural foundation as a profile. Because he inserts one made by himself. So I'm kinda "solving" it by using the file from foundation family.
And if there's another or simpler way to do it, I'd be thankful to know.
Isabel
RDAOU
@Anonymous
It won't work with the family u mentioned first... You need to use a profile family from the box or make ur own which is simple...(do u need a screencast showing how to make ur own profile?)
start new new family and select the Profile template...not the hosted one or anything else ... The simple profile.rft or Metric Profile.rft
and u need to set the usage cuz by default it would be <generic>
RDAOU
The following screencast address the create new profile and set it up for wall sweeps....you will need those profiles for any kind of sweep not sure if there is any easier...
Oh! Thanks a lot. I will definitely practice everything about creating families with parameters. I hadn't realize it's like creating dynamic blocks in AutoCAD. Thanks again!!
