Loading a Column
Loading a Column
tonkata
Loading a Column
tonkata
Trying to load the M_Wood Timber Column form the International Metric Library/Columns/M_Wood Timber Column.
I click on Column/Load Family but get the following error message.
constantin.stroescu
When you chose the comand :Column,:
If you choose it from :Architecture > Column >Structural Column (not Architectural)
or from :Structure >Column
Constantin Stroescu
GHASEM_ARIYANI
You should always use the correct category in Revit.
You can not select columns, structural, architectural columns to load.
When you select a tool for structural columns, you must first log in.
structural folder and then open the folder and Column of concrete, metal, wood use.
For example, you can not choose the instrument door or window furnishings to Load.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
tonkata
Thanks guys.. Been a few months since I've used Revit 😄
