LoadFamilySymbol is not recognize duplicate Type
2 ANTWORTEN 2
Nachricht 1 von 3
kmkxperia
279 Aufrufe, 2 Antworten
I am using the  LoadFamilySymbol to load the family of the M_Opening.rfa it is working fine with the OOTB types loaded in it.
Now if I create the Duplicate Types it is not recognizes that
Code: if ((document.LoadFamilySymbol (fileName,type,out familySymbol)))
It Recognizes  This is working (fileName,"0762 x 2032mm",out familySymbol)))
If I create the Duplicate type of "0762 x 2032mm" Say "DUP_OPE1" and try
It Does not Recognizes  this (fileName,"DUP_OPE1",out familySymbol)))
Any idea why it does not recognize 'LoadFamilySymbol' the duplicate type "DUP_OPE1"
2 ANTWORTEN 2
Nachricht 2 von 3
Sahay_R
als Antwort auf: kmkxperia
I think that your query should go to the Rev it API Forum.
https://forums.autodesk.com/t5/revit-api-forum/bd-p/160
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 3
kmkxperia
als Antwort auf: Sahay_R
Thanks updated it Revit API forum
