I just downloaded yesterday some families , but when I am loading families it load for a second but after that nothing happened . I try dragging the family from my files to revit and that’s it nothing is happening as well.
thank you in advance
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
…hi @Anonymous
…all the families are probably loaded.
….after loading them, go to architecture tab/component.
….Then use type selector under the properties pallet to choose the component which you are going to place.
…. Go up and down the list of loaded families and choose one
…. Then place it into your project
….Note that loading the family and placing it is not the same thing
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Thank you so much for this! I was about to post on the forum for a similar problem because i loaded my lighting ceiling bulb using both load family and the Autodesk one but it'd load and nothing would happen. Then i go to the component tab to place a component and its there.
