loaded family not in project family browser
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
917 Aufrufe, 1 Antwort
Okay, so I loaded the "Door-Curtain-Wall-Double-Storefront" family into my project without any errors. However, when I type DR or click the door option in the ribbon the family does not appear in the family project browser as an option. I've loaded it into the project multiple times to see if there were any errors, but it asks me every time if I would like to overwrite the existing version/parameters. I click yes, etc, but still no option for the door family. Typically after you load a family and you choose that command for that type of family, the most recent loaded family is the default, however, this again is not the case. Has anyone else encountered this issue and knows how to fix it? Thanks!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
You cannot load CW door using the Door/Load family.  Use Load Family on the Insert Ribbon.  You also cannot insert CW door using Insert Door command like with normal door.  To insert it in a CW, select a panel (unpin if necessary) and change the panel type to the CW door.
