Load Family 2022 - Content Folder is Empty
5 ANTWORTEN 5
Nachricht 1 von 6
981 Aufrufe, 5 Antworten
Hi everyone,
I have downloaded Revit 2022 and Content Family Library separately. I can see the content of Family Library if I go to Computer - Dick C - Autodesk - Family Templates - English Imperial. However, when I try to access the contents from inside of a Revit file, I find the Family Templates - English Imperial folder is empty. What should I do. The library is there and not there at  the same time....
Thanks a lot to everyone!!!
Lena
5 ANTWORTEN 5
Nachricht 2 von 6
amarkonathala
als Antwort auf: Anonymous
Make sure u are searching in the correct location only,
C:\ProgramData\Autodesk\RVT 2022\Libraries
while if u are downloaded after the installation u should keep those into the respective folders then only u can see in those folders* or otherwise load from ur downloaded location!
**Thanks
Nachricht 3 von 6
ennujozlagam
try this and see if helps. thanks
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 4 von 6
RDAOU
@Anonymous
2022 content library will not be downloaded with the software, you have to download and install separately or use the load from the cloud... below is the link to the various Content Libraries you can download
Autodesk Revit 2022 Content | Revit Products 2022 | Autodesk Knowledge Network
Nachricht 5 von 6
als Antwort auf: amarkonathala
Thank you all for trying to help me. I still cannot solve the issue. I will leave that libray thing for now and move on to the next topic. Thank you very much for trying to help me!
Lena:)
Nachricht 6 von 6
als Antwort auf: ennujozlagam
Thank you for trying to help me! I must be doing something wrong and cannot explain it. Thanks again!
L
