load auto cad file using Cad link in revit
richard_pineda
richard_pineda
Here is my question of my problem: When I tried to load a Auto Cad file into Revit using Cad link this what get:
None of the created elements are visible in Floor Plan: Furniture Plan View. You may want to check the active view, Its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
    Can someone answer my question please.
[email protected]
Here's a list a 33 reasons you can check through:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
syman2000
Which version of AutoCAD and Revit are you using. If you are using AutoCAD 2019 and link in CAD into Revit 2018, it will give you that message. One way to overcome this is to save your CAD to older version.
Mohamed-Nassar
check you link it in the same view, may u like it in another view
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
richard_pineda
Thank you for solution, I had my crop on to small so when I made crop larger I saw the cad link it was in different location and it was rotate. So I know view it and now what I can do now.
    Thank you very much for your knowledge on this.
Richard Pineda
Specialist 2 Architectural
SLCC
richard_pineda
Thank you for help!
richard_pineda
Thank you for your help!
