Load A Generic Annotation Label
PhilvK
Advisor Advisor
Message 1 of 11
PhilvK
I created what i thought was a simple generic annotation label, but it doesn't appear after I 'Load Into Project', What simple step am I missing please?
Replies (10)
Message 2 of 11
RDAOU
@PhilvK
If it is a Label only and you left the parameter value blank, it wont show in the project till you fill it...
In such case>>>  Edit the Annotation family >> GO to Family Types and give the Label's parameter a default value
Message 3 of 11
PhilvK
I had a default as text, then changed to to a number which is how I want to use it, but still don't see it in the project anywhere.
Message 4 of 11
RDAOU
@PhilvK
Where did You gave it a default value??, it needs to be a Value for the parameter used in the label ie: under Family Types Dialogue...not in the Preview Field of the label
You can also upload the GA if you like??
Message 5 of 11
Did you just load and place the Generic Annotation directly in the Project via Annotate=>Symbols.  Select the Anno in the View, or in the Project Browser, and enter a Value for the Label.   If you want different Annos to show different Labels, then Duplicate and Name additional Family Types that have different Label values.
Message 6 of 11
PhilvK
Where you underlined in red is where I set the default, but it isn't carrying over to the label. The family is attached if you have time, thank you!
Message 7 of 11
RDAOU
It is an instance parameter ... Select all and Overwrite values
Message 8 of 11
PhilvK
I've tried that. The problem is that nothing is appearing.
Message 9 of 11
RDAOU
@PhilvK
You are using an instance parameter these do not carry over...you need to "Select All in View" or Project and overwrite values ... as in enter a new value (Otherwise change the Parameter to Type parameter)
Message 10 of 11
Seems to work fine here.
....above screenshot is taken in the Project Environment.
Message 11 of 11
PhilvK
Thank you both very much! I re-read the posts and discovered the one to enter it as a SYMBOL! Working fine now, and thanks again.
