Is there a way to list all the linked image files and their directories?
We have Revit installed on each workstation and the materials are located on our computers, not on the network. I've found that when someone opens a shared Revit project, the material files that are local do not show up, so there is a huge discrepancy.
Do you know of a way to generate a list of the material images that are actively used? Perhaps a Dynamo definition or some other method.
Thank you!
Why not create a central location? We have a central location with our materials, templates, libraries, etc. I think that would be the easiest solution.
We will certainly do that in time, but it does not solve the issue right now.
Hi @Anonymous,
Try to copy the material directory to each workstation, and link the directory into Revit as illustrated below, Go to Application Menu - Options - Rendering - Click over the green plus mark - Click over the browse for folder button - Open the material directory. Hope it may help you.
