Linking Revit and Microsoft Project
2 REPLIES 2
3508 Views, 2 Replies
Hi, I read something about a software tool, developed by Autodesk Consulting, that uses a bidirectional link between Revit and MS Project however I couldnt find it yet. Anyone knows from where I can download it? And if it is compatible with Revit 2012 and MSP 2010?
Shayan
2 REPLIES 2
Me too, I need to find something that does this for Revit 2015.
boikoartem
I have published my new course on Udemy:
Microsoft Project Management in Revit with 4D Time and 5D Cost
This course “Microsoft Project management in Revit”, will present how real-life Revit projects have used the Tool Dynamo - to calculate working hours and working costs and with the help of an example, I’d like to show you how you can use project management 4D Time  and 5D Cost  in Autodesk Revit.
We will take the volume parameter of the building elements otherwise Revit-Families – then we will translate these volume parameters into time and cost.
The resulting data you can use in a variety of other programs for the control of the timing and the cost of construction. The obtained data can also be exported in another process management software Microsoft Project or other planning tools – such - scoro, asana, smartsheet, monday, hive, ganttpro or others.
Forma Design Contest
