Linking note to object's properties
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
462 Aufrufe, 6 Antworten
Is it possible linking into "Type Properties" a notepad or a *txt file?
6 ANTWORTEN 6
Nachricht 2 von 7
RobDraw
als Antwort auf: Anonymous
To what end?
Rob
Nachricht 3 von 7
als Antwort auf: RobDraw
Because I have created an object and I want to share with my mate, but I'd like to specify some point. I thought to link a note.
Nachricht 4 von 7
Add parameter into your families called Notes...make sure it is Text.
You can also just add the text in a view that can be seen when opened...just be sure to delete when closed.
If you create custom parameters for your families, you can add Tooltips to explain what they do when you create the parameter.
Nachricht 5 von 7
Use Comments field to note Instances, or Type Comments field to note Types.
Nachricht 6 von 7
als Antwort auf: ToanDN
Could you post here some screenshot please?
Nachricht 7 von 7
