Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Linking exported RVT files from Inventor to Revit - Autodesk Docs
2 REPLIES 2
jorn2B4KZ
303 Views, 2 Replies
Hello, I work as an BIM-manager, and I have a project where one group is modelling in Inventor, and the other group in Revit. I have checked out the new interoperability between this products, and exported an RVT file and placed it in the document manager in Autodesk docs.
The problem is that the RVT that gets exported from Inventor does not show when i try to link it in Revit from autodesk docs. If i download the sourcefile locally to my PC I can link it in, but I suppose that there is some kind of fix on this?
All help are appreciated.
2 REPLIES 2
RDAOU
in reply to: jorn2B4KZ
@jorn2B4KZ
Which version of Revit are you using? and do you have Autodesk desktop connector installed
You seem to be going through External Resources when you should Link >>> This PC\Autodesk Docs\...
jorn2B4KZ
in reply to: RDAOU
 I was 100% sure that I had checked this, but this was the solution of my problem. Thank you!
