Situation here - we are trying to link in a site plan DWG that has been received from a consultant. It has been geolocated, has been done in decimal units, scaled down to 1"=40'-0", AND has extents in excess of the mandated 20 mile limit. This makes display of the linked file in the Revit view go absolutely crazy.
I did try to CTRL-C and CTRL-V the DWG objects to a new DWG - in the hope that the extents would adjust according to the drawing objects, but AutoCAD gives me an error message that says that COPYCLIP has failed.
Question - is there any way to adjust the extents of the AutoCAD file to make it easier to work with?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Sahay_R
The best bet would be to eliminate unwanted objects in the dwg, did you check the Z coordinate for any weird lines etc?
Another option would be to create separate purged blocks and insert them in Revit as separate links. (Zone a- site plan/ Zone B- site plan etc)
See a similar discussion HERE
Let me know if this helps.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thank you, @Viveka_CD! Per the discussion, I attempted to WBLOCK the site out of the DWG, and got this error message -
Also - I get this weird situation when I look at the Z -
The circled objects are higher in the Z. They are a Block Reference. When I go to edit the block in place, I get this -
Hi @Sahay_R
Can you filter the layers and find out the proxy element? That may cause this type of error.
Viveka CD
Please see - Error: "Wblock operation rejected due to a proxy object that does not allow copying" in AutoCAD
and try if the solution provided works for you.
Viveka CD
