I have linked a Coordination Model to a Revit Model.
This coordination model is visible in the 3D view but not visible in the Plan and section views..
In the 3D model, When I turn on the Section box, check mark Coordination Model disappear.
Is there any solution is available for this?
Swapnil
It may not show in a floor plan view due to the model having an height value saved. What position origin did you use when linking?
Do you have a Site plan view ? Does it show there?
If not then adjust the views cut plane to 100m and set an unlimited top offset and bottom depth.
Did you even found a fix or a way around this problem.
I'm experiencing it too and I can't seem to find any information on it.
