I just linked a CAD file into Revit and the original file was in black and white. While tracing wall in Revit i cant now see the position of doors and windows. Can you help in any way
IamKilama
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @kilama1331
Did you check if they are hidden in the views, or in a different workset/ phase?
What are the view range settings?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
How can i access that?
well, i have brought it to the foreground. After inserting the windows and Doors, i took it back to the background.
Bring it to Fore ground, and use Wireframe mode..
There are many possibility...
File CAD in another level or out of you range of visibility.
File CAD out of your crop box
Visibility of imported CAD files off
Scale of CAD file
Can you share the file so we can help you?
Hi @kilama1331
Once you open your project in Revit and link in your CAD dwg you can check if the door/ window layers are hidden.
Type VV/VG (visibility graphics) or Go to your view tab> graphics panel> visibility graphics> expand you dwg and see the listed layers - see if you have checked the doors and windows.
See image below:
VG
Let me know if you have any questions and if this helps.
Viveka CD
