Linking CAD file: Limited Positioning options
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Redrunner92
478 Aufrufe, 3 Antworten
For the past few CAD files my civil engineer has sent me, I have not had any of the "Manual" options in the Positioning drop-down box. Why is this option sometimes available and sometimes not? I'd like to be able to manually place the files.
No "Manual..." options providedNo "Manual..." options provided
Tags (3)
Beschriftungen (1)
  • Link
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Redrunner92
Place Auto - center to center then move it to where you want.
Nachricht 3 von 4
Are you going to Insert=>Manage Links=>Add.  No manual when you do it that way.
Just click on Link CAD on the Insert Tab.
Nachricht 4 von 4
Mohamed-Nassar
If u can share a picture with us to see this issue it will help us Sir, i hadn't faced something like this before, by the way i recommend to check CAD File Units to see, is it accepted for you your scale or not may u link it but CAD has not good scale so u can't see it try to check unit then use Center to center Manual this way help u to put it in the place u need and also check if the scale is good for u, don't forget to see this link if u need any provide infor for this workflow
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
