Linked views of the linked model visibility issue
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
1038 Aufrufe, 12 Antworten
Hi All,
We have a constructor's model in Revit, which when linked, does not exhibit all the views it contains.
So far we tried to:
  • Link it to the new empty Revit model
  • Tried to create new views in the constructor's model (they aren't displayed also!)
  • Resave the constructor's model (nothing changes)
  • Opened the constructor's model with the "Audit" checkbox (passes ok, no errors)
  • Delete %temp% windows folder
  • Reboot, Repower, Reopen
The only uncommon thing with the file is the 3-rd party plugin, used by constructor, which is SOFiSTiK Reinforcement Detailing, which is not installed on architecor's Revit PC.
Please help to investigate the issue.
Revit Architecture  - 2020
Beschriftungen (2)
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: Anonymous
Look to me like all the Plan Views are shown in your available "By Linked" Views List. What *PLAN VIEW* is missing?
* hint.
Nachricht 3 von 13
They look correct.  You only see the same view type in the Linked view list. i.e. Floor Plan in your example.
Nachricht 4 von 13
als Antwort auf: ToanDN
Not that easy. I have "structure discipline" (among all others) checked in both
- Options - User Interface - Structure Tab
- Visibility/Graphics Overrides - Filter List
which usually leads to exhibition of all Structure plans in the specified list.
It works fine when, let's say, I create a new model with the Structure plan, save it, and than link it to my main model.
Nachricht 5 von 13
Are saying that the "Structural" Views in their View List are Plan Views -- and that these Plan Views don't appear in the drop-down list under By Link View?
Nachricht 6 von 13
The screenshot simple example
Nachricht 7 von 13
als Antwort auf: barthbradley
Yes, constructor's structural views are created as a Plan view, through Plan Views - Structural Plan, like this
Nachricht 8 von 13
Do you have nested links?
Nachricht 9 von 13
What you said above have nothing to do with the views you see in a Linked view list.  The reason you are not seeing the structural plans is that they are looking up like a ceiling plan, not looking down like a plan.  So, go to a ceiling plan and you can see them.
Nachricht 10 von 13
The constructor's model contains links to the models that I don't have (push continue button on open when tells me the links are missing)
Nachricht 11 von 13
Huh? Structural CEILING Plan? When was this?
Nachricht 12 von 13
Nachricht 13 von 13
Thanks a lot!
They are all there - in the cealing plans, as you said.
