Linked structural model obscured by filled region.
4 ANTWORTEN 4
Nachricht 1 von 5
jsrlrpc
335 Aufrufe, 4 Antworten
Hello, I have a linked structural model that is sandwiched between a pilaster that is beyond and a section cut of a mezzanine. I am trying to hide the pattern of the pilaster beyond but keep the structural elements shown. The problem is when I draw a white filled region and hit "send to back" the linked structural model will still be behind the filled region.
What can I do to have the linked structural model show up in front of a filled region that I draw?
I have attached an image for help.
Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: jsrlrpc
Post both RVTs.
Nachricht 3 von 5
jkarben
You could modify the shape of the filled region to include the shape and line weight of the structural element.
Nachricht 4 von 5
jsrlrpc
als Antwort auf: jkarben
I know that is a possibility, but I'm trying to avoid that because if a change happens to the structure, then the whole outline needs to change with it.
Nachricht 5 von 5
jsrlrpc
als Antwort auf: barthbradley
Can you be more detailed? What exactly do you want to see?
