Linked structural model obscured by filled region.
4 REPLIES 4
jsrlrpc
242 Views, 4 Replies
Hello, I have a linked structural model that is sandwiched between a pilaster that is beyond and a section cut of a mezzanine. I am trying to hide the pattern of the pilaster beyond but keep the structural elements shown. The problem is when I draw a white filled region and hit "send to back" the linked structural model will still be behind the filled region.
What can I do to have the linked structural model show up in front of a filled region that I draw?
I have attached an image for help.
Thanks.
4 REPLIES 4
in reply to: jsrlrpc
Post both RVTs.
jkarben
You could modify the shape of the filled region to include the shape and line weight of the structural element.
jsrlrpc
in reply to: jkarben
I know that is a possibility, but I'm trying to avoid that because if a change happens to the structure, then the whole outline needs to change with it.
jsrlrpc
in reply to: barthbradley
Can you be more detailed? What exactly do you want to see?
Forma Design Contest
