Linked room - tag all not working
2 ANTWORTEN 2
Nachricht 1 von 3
647 Aufrufe, 2 Antworten
Has anyone ever had issues tagging all rooms from a linked file?  I can tag all doors withut any problem, but in the same file, I just can't tag the rooms...
This is with Revit 2015
2 ANTWORTEN 2
Nachricht 2 von 3
stevecrotty
als Antwort auf: Anonymous
This seems to work. Can you double check that when you try to tag all rooms the option to tag linked elements is checked?
If this does not work for you we would need you file to investigate.
Steve
Nachricht 3 von 3
als Antwort auf: stevecrotty
WAs there ever a solution for this issue? I am having the same problem in Revit MEP 2016.
