Linked Revit Model does not appear
Message 1 of 18
I am having an issue with a linked revit model that i bring into my project. It only appears in 3D & some elevations, but does not appear in any floor plans. I have played around with my view range and depth clipping. In what i researched, it may also have something to do with my visibility graphics--> Revit Links (display settings; Host View) but as i open these host views i can't seem to edit or change to custom setting. Can anyone help me with this? Thanks
Accepted solutions (3)
Replies (17)
Message 2 of 18
Sahay_R
This just happened to me this morning. I was asked to take a look at a view which was associated with a different level, so the link did not show. Entirely unexpected place to look for the problem.
So firstly, look at your view properties, make sure that it is associated with the right level!
The screenshots that you sent -
Screenshot #1 - click on the + sign next to the linked file. When it expands, look at the settings of the file that you see. Surprisingly, that has also been known to affect display of the model.
Screenshot #2 - you were in the right place where you were changing out of Host View. ALL of the button below will allow you to switch display settings from Host to Linked View settings. Experiment with them.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 18
Thanks for your reply!
I have reviewed my view properties, and they appear to be associated with the right level. Revit Link 3.jpg should show the +, i'm not really sure what the 4 (<Not Shared>) row is for. When I open to Custom, ALL the dropped downs do not seem to be available and my options are limited. When i researched this, it showed example of what might appear, and i don't have them. Do you think its the way my Linked model was created? (Adaptive component families made from inventor models)
Message 4 of 18
It is getting interesting.  Does your link model have the same Levels as the master file?  Does it have floor plan views, or RCPs, or elevation views created?   If the link file is simply a 3D model for coordination then use by Host View.  Make sure the category of the adaptive component (Generic model?) is made visible from VG of the View you want to show it.
Message 5 of 18
@ToanDN
My Linked Revit model is just 3D, there are no floors/views associated with it. We made the adaptive component as a Curtain Panel family. Everything is turned on in the VG, and by Host View nothing seems to appear. See attached screenshot. Thanks
Message 6 of 18
Sahay_R
The Linked View drop down says none because you don't have views set up. Try clicking on the drop-downs below - if they were inactive they would be greyed out. Play with the settings - maybe changing to By Linked View would help?
Rina Sahay
Message 7 of 18
Then it does not have linked views for you to pick from. Forget about it
and keep it to use Host View. Did you check the category visibility?
Message 8 of 18
@Sahay_R
I am not able to select the Linked View option, and still messing around, nothing seems to appear
@ToanDN
I have checked ALL categories in VG and everything appears to be turned on... the weird part is, if i take a section from a floor plan where my linked model does not appear, it appears in the sections. I don't understand it. Is there a setting i don't know about where it only effects floor plans?
Message 9 of 18
Open the link file and add a Level. Create a floor plan view for that level and see if you can see anything.
Message 10 of 18
@ToanDN
I opened the Link Model and was able to create a floor plan in which it shows. Just still not showing in the project  i'm linking into. I also deleted a couple levels in my project and recreated, linked model still does not appear.
Message 11 of 18
Now you already have one floor plan view from the link, you can change the link VG to custom and pick that view from the linked view list.
Message 12 of 18
@ToanDN
It worked!! Who would have thought you need a floor plan. I guess somehow its all related to the Host View. Thanks so much!
Message 13 of 18
MarkSimpson
I spent all day trying to figure this one out, and most of the comments in the forums didn't solve my particular problem.  It's probably because I'm a novice, and am still learning the basic Revit functionality.  I'm sure that others in this forum already have this knowledge, but here's what I figured out, for those people like me who may still be having an issue:
I first started out a new project file with a default "Electrical" template file that ships with 2018.  This file already includes Levels and Views for 2 floors.  When I linked in the Architectural model, the default plan views for Power and Lighting don't show any of the building components, except for the grids.  Everything would, however, show up correctly in the elevation views.
Here's why:  The Levels and associated Plan Views that were pre-defined in the template file didn't match the actual elevations of the levels of the Architectural model.  So I had to delete the 2 pre-defined levels (which automatically gets rid of the associated plan views).  Then I linked in the Architectural model and performed a "copy/monitor" on the Grid lines and Levels.  Then I had to create new plan views.  Everything automatically showed up correctly after creating these new plan views that were associated with the correct architectural Levels.
I will also add that before I figured this out completely I was able to do a workaround by modifying the V/G overrides for the linked Revit file, so that the view was "By Linked View", then selected a view from the linked file that was most appropriate for what I needed to show.
Hope this helps somebody...
John
"BIM me up, Scotty!" -Captain Kirk
Message 14 of 18
saba_vaseghie
Hello There,
I have a huge master file and  I am trying to link Revit Model into it. The model to be linked, has floor plans and elevations. When Link the model into the master Revit file, it does not show in the site plan so I can place it correctly where I want. It shows in the 3D, however when I go the 3D to see where it is relative to other buildings, I can't locate it and it looks like it is very far from the other buildings and I can not even find where it is if I hover too much. I can not find it in the site plan as well. Are you able to help me with that?
Thanks in advance.
Message 15 of 18
Sahay_R
Possibly the link is too far from your model and is breaking the 20 Mile Rule?
Type VG.
Under RVT LINKS  sure the link is checked (if you see a + next to the linked file then expand it - make sure all the files yiu now see have a check mark).
However - it does sound that the link is way too far from the origin. Type in ZE (Zoom Extents), window select over the ENTIRE drawing window. You may see a little pin point which is where the link is - click and drag it close to the center of the screen. ZE again.
Repeat this process till you have dragged to the link close enough to be able to see it well enough to place it the way you want it.
Alternatively - remove the link. Relink the file, experiment with the placement options that you see at the bottom of the dialog box.
Rina Sahay
Message 16 of 18
saba_vaseghie
Hi Rina,
Thank you for the reply. I was helpful. I noticed there was something going on with the levels units. in the master file I had them in mm and in the linked file was m. So it was very high in height when I imported it.
Message 17 of 18
ea548
Community Visitor
Community Visitor
I had the same problem. I am working on a architectural model and trying to link MEP model on it. As I realized, crop view section at the bottom of the 3-D view could be checked, it should not be active. Clicking the crop view by mistake while tring to link the model could be considered as an alternative option.
Message 18 of 18
patelashutosh17
Community Visitor
Community Visitor
Few major items to check here,
  • Project coordinates - shared, origin or internal origin
  • Project Phases - Very common to have a different project phasing causes the link to disappear
  • cropped view, uncheck crop region, and set to none. Check for the section box as well.
  • Linked Project has an instance placed
  • The linked Project workset is hidden/not visible
  • 3D Template has filters, advice to remove templates and try to reset everything and see
  • The link has been set to hide in view, click the light bulb
  • Linked file has gone bad, redownload or if it is on ACC/BIM360 try to link a locally downloaded file
