I linked a consultant's Revit file into my project. I created my own levels. I also know how to not show their levels in my views.
But when I create a floor plan view, the selection still gives me their levels. this is clutter to me. See below the 2 highlighted levels are in my project and are the only wants I want to see to choose from.
How do make the linked ones NOT appear? I tried the link to be overlay and attached. and the template for the view I want to create ( "A ") also is set to not show levels.
I don't' link a lot and imagine if you link multiple files this gets worse. Especially since they used levels for all kind of things that shouldn't' be levels IMHO.
Gelöst! Gehe zur Lösung
Gelöst von seydauzun. Gehe zur Lösung
Hello @HVAC-Novice ,
Did you copy/monitor links with their levels? I was curious when i saw your message because i link a lot of models, and it bothers me sometimes. When i link i copy/monitor levels of 1 link and i get all their levels always visible like in your case.
Now i deleted the ones that i copy/monitored unnecessarily, and problem solved. If you do not need that levels and you copied from linked file you can delete them i guess.
I only copied the grids, not the levels from the link. But I found I had their grids in my project since I originally "bound "their link. I found all remnants inc. levels from that binding and deleted them. Now I only see "my "levels when creating floor plans.
Thanks a lot.
