I have linked in two Revit Architectural projects into a host project. I want to show the annotations and fill regions etc. I go into Visibility/Graphics, then the Revit Links tab and the links are greyed out. I want to change the Display Settings to by Linked View. I want the plan view to be linked into a plan view. Both the linked view and host view are named the same with identical levels. How do I get the linked view to not be greyed out?
Thank you.
Kory Skoog
Project Manager
Gelöst! Gehe zur Lösung
Gelöst von brettgatti. Gehe zur Lösung
Are you using a View Template for this view? If so, you may want to remove (uncheck "Include") the V/G Overrides RVT Links category so that you can control it individually per view or make the change that you want in the View Template itself.
That did it. Thank you. I knew is was a simple click somewhere.
Kory Skoog
Project Manager
I am at a loss for where to find that check box, can you do a screen capture of it?
