Linked model reload
Linked model reload
m_husseinAZNUP
Linked model reload
m_husseinAZNUP
Hello everyone. I work on a project, and it has a structural model linked inside the project sheets file... whenever I reload this particular model, it reloads without any problem/error, but it disappear! Same model is linked to another project file too, no issue there.
Any thoughts or solutions for this? It's really annoying, because I need to close the project and open it again to let the structural linked file appear again!
Note:
-I use Revit 2021 version (Licensed)
-CDE for this project is BIM 360.
-Project sheet file has 13 linked files inside it. Only STR link has this problem. Reference type for this link is Overlay
Please let me know if anything else is needed to identify this problem.
SteveKStafford
Check the view(s) Far Clip setting, try changing the choices to see if it reappears.
BIM 360 - make sure the file has been published (if that project is configured so that publishing is required)
Steve Stafford
Are the models using shared coordinates?
m_husseinAZNUP
No, internal origin to internal origin
m_husseinAZNUP
The model vanishes from everywhere (views, schedules,...)
And yeah everything is published
Since the link reappears after a restart so its position is not the cause.  Try clear collaboration cache and install the latest desktop connector.
