Hi all,
Is it possible to see IDs of linked model?
you can Reload the Lilnk for you only and you will find ID for the Item or By Using Navisworks Switch Back.
Regards,,
One alternative would be to open the linked file in a second Revit session. You can use that session to look for ID's
Small Dynamo script also could help. Here a concept. When run it allows you to select an element in the linked file and Revit will return with the ID
Louis
Please mention Revit version, especially when uploading Revit files.
That may work.
My question is how to return this ID element into Original revit model (Where the link is uploaded).
My idea is:
In master model (for coordination) I have several linked discipline models.
I want to run Interference check in Revit (no OOTB tools) and create a report with ID.
How can I?
