Hi there,
New user of Revit so please excuse me.
Please see attached picture...
I have imported a linked revit architectural model into a mechanical template and added some systems. I would like to show the model in 3d view with realistic colouring. The problem i am having is that when i set the colour setting to 'realistic' the items that i have added in the mechanical template show up with the correct colours, but the linked architectural model remains colourless.
Please could somebody advise on what i have to do to enable the linked model to be coloured?
Many thanks,
Callum
Revit 2016
Hi @Anonymous
did you checked that the linked model visabilty graphic is set to "by host view" and not "by linked view"?
Also, if you have Phases set up, check Phase Filter in the 3D View--set to Show Complete, so Materials display correctly.
Hi @zemeraloni
Thanks for your reply.
Yes i have checked that. I think i may have found the answer to my own question.
I was viewing the 3d view within the sub category of Mechanica\HVAC...when i switched to Architectural\HVAC\3d Views then the colours appeared on the linked model as expected.
Many thanks,
Callum
