Is it possible to change the material of an imported/linked IFC file?
I can use "Bind Link" → "Edit Group" → "Ungroup" and manually override the color of the element, but this is not the desired solution since I would need to do this in every view.
I already created a Project Parameter, changed the Material, but it did not affect the element.
BTW, sometimes "strange" (duplicate, new elements, etc) things happen to the geometry when using "Bind Link."
