Linked files measurements slightly off
2 ANTWORTEN 2
Nachricht 1 von 3
jonatan.strombergssonY38L2
322 Aufrufe, 2 Antworten
Hi!
I’m sure many of us have used a linked DWG to create a 3D-model in Revit. The problem I experience is that the measurements are inaccurate. Something drawn in CAD with the intention to be 3500 mm of some reason becomes 3499.7689 mm. This inaccuracy becomes a problem when adding angles to the building. Or roofs with more then 2 slopes. Does anyone else experience this? Is there any quick fix like “correct lines that are slightly of axis” but to parallel lines?
2 ANTWORTEN 2
Nachricht 2 von 3
what ever your distance in autocad drawings will come out same in revit? so make the autocad drawing dimensions right. i always set my distance precision to 0.0000 when checking the distance. if your dim style set to round off 0 , your dimensions will be set to nearest tens. just saying thanks
Nachricht 3 von 3
als Antwort auf: jonatan.strombergssonY38L2
If possible, open the DWG in AutoCAD and check for the origin.  Make sure it is not far from the building, as this will lead to inaccuracies.  I suggest not to use the pick line tool when working with DWGs.  Rather use the DWG as a guide and draw the lines.
