Linked File not exporting to DWG
Message 1 of 8
Right, so i have a site model linked into my building model on Revit 2017. I need to export a floor plan to DWG for a colleague, when exported, everything in the new DWG show up perfectly, except for a DWG site survey i have linked into my site model.
It shows perfectly on screen in revit and when printed to PDF
Replies (7)
Message 2 of 8
cbcarch
Is a layer in the exported Cad file turned off? What layer does the linked Cad go on in your export settings?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 8
All layers in the exported file are on. the export contains patrial elements such as falls and level points, but none of the landscaping
Message 4 of 8
Hi @Anonymous,
Have you tried to zoom extent in Autocad ? Maybe the dwg site has a object that is too far from the rest
If you zoom and see nothing, that's because of it
( Sorry if my English is not clear)
Message 5 of 8
Doh, Problem solved. My Survey was being blocked by my topo. just set topography to transparent and hey presto
Message 6 of 8
When exporting to DWG with links etc, go to the extra options menu. From there uncheck the "export views on sheets and links as external references". (see attached image)
Message 7 of 8
HdM_s.kamyab
Observer
Observer
But many consultants want to have the dwg bound and x-reffed and not as a single dwg.
Message 8 of 8
epbmc
thankyou - saved a lot of frustration
