linked cad logo
4 ANTWORTEN 4
Nachricht 1 von 5
kherrman
287 Aufrufe, 4 Antworten
linked cad logo
Anybody have insight as to why some of the letters are showing hatched in revit, but are showing up correctly in cad?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: kherrman
Are they text?  If not, share the DWG here.
Nachricht 3 von 5
syman2000
There are reason why it did not fill those text
1. Polyline is not set to closed inside AutoCAD file
2. The arc or line is less than 1/32" (0.8mm) which is Revit limit
Nachricht 4 von 5
vitorbortoncello
Try to import cad, then partial explode
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 5 von 5
SteveKStafford
als Antwort auf: vitorbortoncello
Did you not notice that this thread is 13 months old? The OP has moved on long ago.
Steve Stafford
