I have imported a CAD file in my Revit file. The imported cad file does not show the same as the original cad file. It is probably because in the cad file x clips have been used in blocks. Is there an easy way to get the right visibility in Revit?
autocad file
autocad file xclip off
revit file
yes, either import cad or link cad, you can see the whole drawings without xclip. try to cut your original drawings in the necessary portion that you want to see? thanks
another way is to crop the view? thanks
There was no easy way to solve this problem. I had to explode all blocks, remove the x-clips and remove all superfluous content. It took me almost two days.
