Linked AutoCAD files not seating properly when linked into Revit Project
I have recently converted from regular Revit to Revit 360. Everything worked fine before the transition to 360 cloud. Now, when I link my AutoCAD dwg. files into the Revit project all the files collapse onto each other in floor plan views. In 3D view and sections each floor plan dwg. is in the proper place. I can single out each dwg. and hide it but once I refresh the links they all reappear and are collapsed on themselves.
How can I link each CAD dwg. to the correct floor plan and have only that one displayed when I am working on the floor plan?
chrisplyler
I'm not aware of any product called "Revit 360."
In Revit, when you link in a dwg, you have the option "Only in this View" that will do what it says.
It's Autodesk 360, they created a cloud version and after we switched over that's when the dwg files started messing up.
